Those who are using a head pressure controller to modulate blower speeds based on plenum temps.
JRHAWK9
2,072
Wisconsin Dells, WI
I'm just curious as to what voltage you all are sending the blower at blower cutoff? I aimed for 65VAC, but there are times my snap switch cuts power when I'm at about 63-64 VAC. Just curious as to what others are using for their cutoff voltage. FYI, one needs a true RMS meter in order to correctly meter the voltage coming out of the controller. If not using a true RMS meter, your readings will not be accurate. This has to be how the controller is rectifying the signal.
http://en-us.fluke.com/training/training-library/measurements/electricity/what-is-true-rms.html
PS...I'm LOVING this variable speed setup!!
Reactions: brenndatomu
@brenndatomu
I know there are a handful of you running this setup on your Tundra's. What is your cutoff voltage?
@brenndatomu
For the record I've deactivated mine. I wired up a pretty complicated system so that it was fail-safe if the var spd failed, and as a result it doesn't work as well as I hoped. I might redesign it (a 3rd time) if I get ambitious, but not in the foreseeable future.
