I stopped reading after a couple of sentences.
http://albany.craigslist.org/lab/2376709018.html
"If you bring and provide your own chain-saw/safety-equipment/gas, I will pay you $10/hour CASH to cut marked trees up to 14 inches in diameter. You must know how to cut down a tree. Generally, I only want the marked dropped, not limbed or chopped. Tree stumps along the road must be cut second time at base flush with ground, so bring spare old chain. I will also pay $4/gallon for the GAS USED each day in the chainsaw if you work at least 4 hours (mark the level in your gas can). Equipment malfunction time or interuptions (saw sounds idling or off for over 2 minutes) will be subtracted from payable time. Smoking is not allowed. Trees cut but left standing/leaning will be docked from your pay at rate of $2 per inch of diameter, unless you pull them down to below height of man (Ropes and winch will be provided, and I will help you pull them down and mark other trees if need be, but this lost time counts as interuption of paid saw work). (If you can't drop it, don't cut it). Cutting or nicking unmarked trees willl get you into trouble.
Camping privileges available on the property.
Other than the tree-cutting with your chainsaw, I will pay $8/hour CASH for unskilled labor to do branch-clean up, light demolition, digging, moving rocks, and to assist me in repairing buildings."
