]Hello
This really nice 25-30 year old deep green True Value Wheel Barrow is expensive to replace. The wheel is squeaky and stiff but it does have the standard 5/8" diameter axle! However the axle. Brackets have an axle housing shaft that are much shorter than the new ones and a non standard wheel to make up the difference!! So a new wheel and 2 Pelpro Auger Set collars will keep the wheel centered so it will not slide back and forth on the axlee![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
The 2 back carriage bolts were turning with the nuts so the only way to remove them is to cut the nuts off with a metal blade on a sawzall. Four New Stainless Steel bolts, nuts, flat washers and lock washers are needed here too!
Has anyone seen this problem???
Do you know if these old True Temper wheel barrows are made stronger and last longer than the new ones?
See pics below.
Pic 1-2 cut the two back nuts off.
Pic 3 - Comparison of new wheel and old wheel shows gap on axle rod. Where the new wheel can slide back and forth. Also shows new srtainless steel auger bushing to keep Wheel from sliding
Pic 4-5 shows Wheel before and after new bolts for auger axle brackets.
See Stainless Steel Auger Set collar with strong Allen set screw. There is one collar on each side of the wheel to keep it centered.
Pic 6 - wheel barrow all fixed and ready to roll
Pic 7-8 -- new Pelpro, Glo Boy, and cheap Charlie Auger Set collar which is 5/8" ID![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
See pics below.
