This was posted in the Garn news for June. The thoughts are those of one of the deans (Martin Lunde) of the wood burning industry and have too much merit to let pass without sharing.
He is absolutely correct in saying that conservation should always be the first category looked at when lowering energy use is considered.
ENERGY CONSERVATION
In September 2009, I wrote an article for GARNews titled GOING GREEN. In that article, I quoted the following excerpt from the GARN® WHS Installation Manual:
Remember this: Eliminating fuel usage is the same as burning fuel with absolutely zero emissions - impossible for any fuel even natural gas! A well designed and constructed energy efficient building can reduce heating demand (thus fuel usage) by at least half, and sometimes by two-thirds when compared to a present day "code built structure."
In the later part of April 2010, I attend a 3 day conference that focused almost totally on biomass fuels. Although there was abundant talk about converting from fossil fuels to renewable biomass fuels (primarily pellets), not a whole lot was discussed regarding conservation. I was dumbfounded! Conservation clearly has the greatest reward for the fewest dollars spent and has one of the lowest environmental impacts. Indeed, conservation must always be the first approach to reducing fuel cost and fuel consumption. This naturally leads to a reduction of emissions over the long haul.
Why the lack of significant discussion? I believe that conservation is not "sexy" - many times it is the old "stuff and caulk" routine. Plus, it is an approach, not a definitive "high tech" new wiz-bang heating product. However, it does involve thoughtful good building design as well as many diverse products such as: insulation, caulking, vapor barriers, air to air heat exchangers, better controls, etc.
Beyond lower fuel usage, lower fuel cost and fewer emissions, the better-built building is healthier, more comfortable and lasts longer. All of these enhance our environment by keeping our earth and its people healthier, by using less energy and sequestering carbon for a long period of time (by not having to remanufacture heating appliances and/or by manufacturing smaller appliances).
One other item stuck in my mind. Most of the discussion revolved around wood pellets, with little mention of cordwood. In fact, a GARN WHS unit was one of only two cordwood burners on display at the conference. Toward the end of the conference an Engineer visited the GARN booth to discuss the GARN WHS unit. It turned out that this gentleman designed pellet manufacturing facilities, so I inquired about the energy required to make pellets. Apparently, a significant quantity of coal fired electrical energy is required to power a pellet mill. Pro-Pellets (an Austrian based pellet trade association) estimates that 5% to 15% of the energy in a pellet is "lost" during the manufacturing process. By comparison, cordwood has virtually zero loss. Neither estimate takes into account transportation energy only "manufacturing energy."
So my question is: Should this "lost energy" be deducted from the energy efficiency rating of pellet fired heating equipment? Cordwood is "more local," has virtually zero lost energy and typically no coal fired electrical energy is required in its "manufacture." Furthermore, cordwood does not require a storage bin or dedicated material handling equipment; thus yielding a lower first cost.
© DECTRA CORPORATION June 2010
ENERGY CONSERVATION
