Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
Is it safe to vent my insert straight up my chimney without any elbows or bends? I thought this would be unsafe as the creasote may run srtaight down on top of the fiberboard and create a fire hazard....Please advise as any help is wonderful!
Thanks for the responses so far!! I am new to the woodburning world and very "Dumb" with some of the stuff! It is a rigid 6 inch pipe up the existing masonary chimney and the said fiberboard is an insulation directly inside the top vent on my englander wood burning insert.
Thanks everyone I was just concered with the creasote getting on top of that fiberboard which is actually the fire box! But based on the responses here it seems this may very well be an ideal option! Now if I can talk my wife into believing that it looks great without a pretty faceplate then I will be all set!!
Not only is a straight up chimney safe, it is generally considered to be the preferred method when possible as there are no elbows to restrict draft which is the "engine" which drives the fire and an added benefit is the ease of sweeping the chimney with no elbows.
Most stoves and inserts are set up so that they either vent out the back or top (but these are generally located towards the back of the stove) and in either case . . . burning well seasoned wood and cleaning the chimney will prevent cresote from coming down on to the baffle board . . . more to the point, when you've got creosote running down the stove pipe (and not just the dry popcorn-like, potato chip-like or dust-like build up) you've reached the point where you've got a serious problem -- either water is penetrating your chimney, you're burning at temps far too cool for your stove or your wood is way, way underseasoned.
Are you sure it's fiberboard? What I think is fiberboard is actually a flammable material. I would be surprised if it were used on top of a stove/insert
The fiberboard is a baffle inside the stove and intended to take the heat. Any creosote that falls on it will burn safely. In fact, having a straight up is the safest way to go. If there is any creosote that builds up on the flue, dries, curls, and drops down, if is immediately burned rather than collecting in a Tee or elbow to be ignited later.
