(broken link removed)
TORRINGTON, Conn. -- Some state lawmakers want to allow local communities to regulate wood-burning stoves.
Channel 3 Eyewitness News reporter Dan Kain reported the proposal involves giving local cities and towns authority to regulate the size of the stack on wood-burning stoves and how often they can be used.
Mike Dryansky, of Valley Fireplace and Stove, sells all manner of stoves, including wood, gas and pellets.
"That's crazy; very frankly, it's crazy," Dryansky said of the proposed legislation. "The chimney -- whether it's stainless steel or brick -- has to go up 2 feet above roofline and far enough to get 10 feet away on a horizontal through a combustible. That's a national rule."
Dryansky said the safety standards for stacks are set by federal and state laws and have remained the same for years. He said he sees no reason to change the regulations.
Kain reported the proposed legislation would prove difficult to enforce because a clean-burning stove doesn't put out any smoke unless the wood is wet or green.
The purpose of the legislation is to protect the health of neighbors who are affected by wood-stove emissions. Experts said if the stove is running properly, there should be no emissions.
