Over 10 years ago, we bought this big Victorian and installed a wood pellet stove in the family room.  It's a big room, about 17' wide and 34' long.  So about 600 sq feet.  It has high ceilings and a crawlspace beneath it with poor insulation.  The walls should be decent insulation though.  According to common advice, in ideal situations you would only need 12,000 BTU to heat 600 sq ft.  Since this is not ideal, we figured 25,000 BTU should be fine.  The PelPro 120 claimed to put out up to 50K BTU/hour, with a minimum of 15K BTU/hour.  We should  be roasting with this stove!
The reality did not work out that way. If we come home and the house is cold (50 F), if we close the doors to keep the heat in just that room and start the stove, then in roughly 7 or 8 hours, the heat will finally reach 65 degrees. That is with maximum feed rate and blowers on high. Over the years I tried everything I could find. Talked to their support tech. Tried every wood pellet stove tuning technique. Nothing I did ever made a difference. It just would slowly pump out luke warm air and take many hours to heat the room. We barely use it anymore. The room heats way faster just putting a fan in front of the steam radiator.
Either there is a serious flaw in the dynamics of my house in regards to the wood pellet stove, or the stove is just a lemon. I'm considering getting rid of the PelPro and replacing it with something more reliable/effective.
I would appreciate any thoughts on either the lack of heat situation, or a replacement that would do a better job.
Brokk...
Brokk...
