Time for me to ask the question of which new stove to buy. I've been thinking about this a lot lately, and with the free shipping sale at Woodstock the timing is right. To make a long story short my wife and I are ending our marriage and I won't have anyone home to reload the stove during my workday. The Rockland can get decent 8hr burns, and I can relite after 12 hours using a large load of EcoBricks (though not really any heat left the last couple hours) but my workday is 14hrs door to door (minimum, not including stopping for groceries, dinner, picking up my son, etc.) so a stove that can get be 14-15hrs or more is needed. Tired of coming home to a cold stove I have to re-lite from scratch and house in the low 50's or even upper 40's. The Rockland really can't keep up with the heat loss of this house during the coldest month or two of winter, even with the pellet stove in an adjacent room and feeding the stove while I'm home all day.
House is around 2400 sqft finished I believe, and half of it was built in 1900 with a cape cod style upstairs that I am working on insulating. I'm unsure if the downstairs walls are insulated either. The new side, with the large great room the stove is in is 1990 but done cheaply with thin walls (2x4) and lots of drafts. I plan on tackling what bit of insulation and air sealing I can do myself, but nothing extreme since I'd rather move than sink too much $ in this place. I'd like to move in ~2 years but could stay up to 9 more years until my son is done with school so I am not so limited on where to move.
If I knew for sure I'd move within a couple years I'd just bite the bullet with propane. But I'm not sure. And I could always take the stove with me, I might even keep the Rockland to reinstall it when I list the house.
Here are some pictures:
The hearth ledge is 16.5" deep also.
Originally we didn't want to mod the hearth so the Rockland was the largest unit that could fit. I think current belief is its around 2 1/4 cuft firebox. Also it radiates little heat. Most of the heat goes straight up, and even 5-6 feet in front of the stove is quite cold on those cold days. I am assuming a freestanding stove will radiate more heat and better warm the 18' high room?
What my idea is to simply cut a hole in the carpet (its trashed and needs replaced at some point anyhow) put down a sheet of durock with brick and mortar on in to match the current hearth best I can. Perhaps make it easily removable to put the insert back in when I go to sell the house. The stove will sit in front of the current 11" tall hearth. I have to pull the cast iron trim off to be sure, but pretty sure the top of the fireplace opening is 26 1/4". So the new stove needs to be able to clear a horizontal run of 37" minus the thickness of the new hearth.
Currently 6" double walled duravent liner (around 22' I think). Bottom few feet is insulated flex, I assume I can pull off the stove connector and add an elbow or tee.
The BK King would probably be the first choice for performance (though last choice for looks). However I assume its not going to work with a 6" Duravent exhaust. In fact, if I recall from reading the Princess manual it has to have like a 3' rise before horizontal? Does that mean its out too? I've been leaning towards Woodstock anyhow, and this free shipping deal makes it a sweet deal. I see both the IS and PH can horizontal vent so shouldn’t have any issues with my hearth set-up. I love the looks of the PH! But like the larger firebox size of the IS. Some have said with the newer IS there are some design improvements as well including things like the air control and ability to idle lower with better control? The price and customizability is sure nice too.
Any other stoves I should be looking at? I guess my overall criteria is most importantly the largest stoves that can burn 14+ hours, and hook to horizontal 6" flue that’s no higher than 37" minus hearth pad thickness. Any advice appreciated, thanks!
~Tristan
![Thinking of replacing insert with longer burning Woodstock, BK, ? Thinking of replacing insert with longer burning Woodstock, BK, ?](https://www.hearth.com/talk/data/attachments/155/155449-467cc682e78a32b1ad1d08993c525831.jpg)
![Thinking of replacing insert with longer burning Woodstock, BK, ? Thinking of replacing insert with longer burning Woodstock, BK, ?](https://www.hearth.com/talk/data/attachments/155/155452-8b088fa147b28be9b582500b3d82a12a.jpg)
![Thinking of replacing insert with longer burning Woodstock, BK, ? Thinking of replacing insert with longer burning Woodstock, BK, ?](https://www.hearth.com/talk/data/attachments/155/155450-544a7d23427cc586e22ff9b7e82b680b.jpg)
![Thinking of replacing insert with longer burning Woodstock, BK, ? Thinking of replacing insert with longer burning Woodstock, BK, ?](https://www.hearth.com/talk/data/attachments/155/155451-a753d93a678f98eb220103f88cbe06b4.jpg)
~Tristan
