I've been thinking of putting a wood stove in my basement ,just to take the chill off when it is real cold. I don't want to try and heat the whole house with it. I will probably burn pallet wood because it is readily available from work. I heat the main living area with a pellet stove , and it does a real good job. I have been looking at Northern Tool at their stoves . I don't want to spend to much for the stove $ 500.00 or less. Has any one heard good or bad of the following stoves, [ VOGLEGANG VG 650 ELG, TR003 VG 650ELG, TR001, VG450ELGB, DROLET SAVANNAH DB0320, DB03060.] All are from the Northern Tool web site. The size of my basement is 650 SQFT. I insulated the walls of the basement this winter . It was 38 degrees when it was real cold and I had to run a vent-less heater to keep the pipes from freezing . Any help out there?
