I want to replace my older 25-PDV Englander pellet stove with a newer 25-CBPAH model. The center line of the existing stove vent is appx 15.5in. The center line of the 25-CPPAH vent is 8.5in. This means the stove vent and the wall thimble do not align.
Is there some way I can connect to the existing wall thimble, or do I need to reposition or install a new wall thimble. I don't really want to do that as it would involve some work to remove outside siding and inside drywall and all the associated fixing and patching that goes into that.
I suppose I could put the newer stove on a 7in riser, which would lead to added costs, access for servicing, and possible code issues with the riser.
Thanks
Phil
Thanks
Phil
![[Hearth.com] Thimble vent alignment. [Hearth.com] Thimble vent alignment.](https://www.hearth.com/talk/data/attachments/317/317132-e9416ee3154a02ac6b7d8d5da1ef92d9.jpg?hash=T89j1ug0gS)
![[Hearth.com] Thimble vent alignment. [Hearth.com] Thimble vent alignment.](https://www.hearth.com/talk/data/attachments/317/317134-6f15491106af4551b5749c0115f353f2.jpg?hash=B_UicfoUb9)
