I received an estimate to reline a masonry chimney in which the installer plans to remove a 22" long clay thimble and simply turn a 90* with the flexible SS liner towards my boiler. He is not going to install a replacement thimble. I have two questions:
1) is a thimble necessary when the pipe is passing through a masonry/stone wall?
2) if the thimble isn't necessary, should there be an air gap around the horizontal part of the T, or should it have insulation or refractory cement to fill in the void?
3) wouldn't a T be preferred to the 90* at the bottom of the flue?
Thanks for your help.
Lee
Lee
