Can I switch between manual and high low while stove is rinning. I hooked up thermostat that came with stove but doesnt seem to work
kykel said:Can I switch between manual and high low while stove is rinning. I hooked up thermostat that came with stove but doesnt seem to work
Brianm58 said:Question regarding T-Stat on the M55. I have mine hooked up to programable T-stat when the thermostat calls for more heat should the heat setting lights move up & down? I have the heat setting on #2 during the day & set @ 66, when it kicks in @ 3PM to go to 70 the heat coming from the stove jumps up, but the light stays @ #2. Does this make sense?
Thanks
