I've posted before about the trouble I'm having with my MT Vernon. I'm on my second season with this stove and it's driving me crazy. This stove has a mind of its own. First everything has been replaced on this stove and some items have been replaced 3 times. The problem I have now is the thermostat. When you go to use it most of the time it blinks then goes blank. You can't do anything with it, you have to disconnect it from the wall then put it back on. This works sometimes but most of the time it doesn't. Sometimes if I want to change the temp or shut it down I have to fight with it and sometimes it takes like 15 minutes to make a little change. I had my electrician run this wire. Last year they ran another wire and we hooked it up to the stove and we had the same problem. The other day I powered the stove down and it went out like normal, but then for no reason it goes back into startup mode. I shut it down to clean it, which i do a lot and this stove is as clean as a whistle.
I have the original baffle, because I remove it once a month and clean behind it. I have electric heat so I rely on this stove to heat my house. The place I bought the stove from have been good about replacing everything and I'm lucky they stock all the parts. There coming out to replace the thermostat for the second time. I'm not sure this is going to fix it. Has anyone else been having this problem?
