I have a gas fireplace (Fireplace Xtrordinair 36 DV XL) with a millivolt system. It's around 20 years old.
I'm using a millivolt compatible digital thermostat (White-Rodgers 1E78-140),
but often there is not enough voltage (~459 mV) from the thermopile to operate
the thermostat - it does not open the valve when called for heat.
Sometimes it works if I switch the heat off and on a few times, or wait a few minutes.
I can always start it using the manual switch under the fireplace.
I've tried a different thermostat (Honeywell CT53K), which is mechanical, with no difference.
I've replaced the thermopile and cleaned the gas orifice, which helped a little, but still having problems.
One thing I noticed is that I get more voltage from the thermopile when the glass cover for the fireplace is off.
Then the thermostat works fine. Could the problem be caused by a blockage in the air intake duct?
Is there anything else that could cause low voltage from the thermopile?
Thanks,
Mike
Thanks,
Mike
