ThermGuard to help keep bedrooms warm?
gbeane
17
Brewer, ME
I am thinking about installing a ThermGuard to one of my heating zones. This serves the upstairs of my split level house. On this floor there is an open living room/dining room/kitchen, and then three bedrooms and a bath all on the same zone. The pellet stove keeps the open area quite warm, but then the bedrooms get a little cooler than I would like at night (especially my 6 month old's bed room). I am thinking about playing with the thermostat (in the hall way closest to the open area with the stove, furthest away from the son's bed room) and stove settings at night to hopefully find something that will keep his room 62-64 at night, or just get a ThermGuard and find a setting that will run the heat enough to maintain a temperature in the 62-64 degree range in his room.
any advice?
I have two zones, the ThermGuard is on Zone1 (first floor) since that’s the floor that’s heated by the pellet stove, Second floor (Zone 2) I have a digital Thermostat set to keep the floor (only bedrooms) to 63 at night while we sleep, then turns down to 50 during the day when no one is up there.
If you can’t do something similar then I don’t see why a Thermguard can’t be set to say run every hour for 10 Minutes to keep a level heat. Not sure what the setting would be to keep it around 62-63, but I know that when ever the weather changes out side you will need to change the durations or frequency of the Thermguard to keep the same heat range.
Have a raised ranch with insert in lower level family room. first year I used it my thermostat was close to top of stairs. Bedrooms were really cold. I moved thermostat down the hall near my bedroom door.
The least expensive way to insure that the little ones bedroom is going to kept at the mentioned temps is to install another thermostat in the bedroom or any bedroom, connected in parallel with the existing thermostat for that zone. Doing this, either one will create a call for heat from that zone, even if the existing thermostat is satisfied.
duh!
not sure why I didn't think of that.
