And since I am a relative newbie here, I'll ask anyway: How do I know if I should cut down the smoke flue damper instead of adjusting the combustion air door? Both methods reduce the amount of air going through the system and supporting the fire.
If your talking about yoru Winter Warm then you need to shut the damper down when you reach proper flue temp to light of the catalyst. Once that is acomplished just control the rate of burn through the primary air controls.
I'm no expert and I dont have a charmaster, but based on my experience I now keep my damper on my flue open all of the time. I also fixed my barometric damper and I am burning less wood now, while keeping my secondary combustion going. I just use the main dampers on the furnace itself to control the burn.
Well since I don't have a charmaster this is just generic advice but I would try to control the thing primarily with the air controls on the front of the stove, and only use the damper when further control is required.
