Is there a proof of fire switch on that stove? I have no manual to see if there is one that would need to be satisfied in order to keep the stove running after startup cycle like many other stoves. Also as Smokey just beat me, vacuum issue caused by several issues and this stove runs on 12 volt brush type motors that wear and weaken pretty fast.
Get the manual out and try and find that switch. If its very dirty it should try and shut the stove down if it thinks things are not firing. Usually a 120-130 degree snap switch. Common problem with Whit stoves.I don't know abt. a proof of fire switch, but it must have some kind of sensor, because when the pellet feed stops and the fire goes out the fan stops running. I wiped the fan intake clean like the manual says, I'm gonna try to vacuum it but the intake is very close to the floor !
Yes, T1 and T2 are the probe sensors. The Thelin does not use snap switches but instead probes.Mine does not have electronic ignition. I looked in the manual no mention of any switch, just says it will shut down if hot, no ignition etc. I assume the mother board takes care of this, but there must be a sensoe that tells the mother board ??
So they are using temp probes to a smart control panel. I had one go bad on a 4 year old Hestia. I would take them out and clean them and clean the areas- passages well.
Someone needs to find me a cheap hard drive to extend my poor old computers file space![]()
This guy had the same problem, never posted a fix ! https://www.hearth.com/talk/threads/my-thelin-pellet-stove-is-going-out.79414/
Now there is more that just that tee in the vent system.
Used stove, in good shape, but worked fine until now, the guy told me it had a new auger motor. So its a used stove with brand new chimney ! Before I put it in I cleaned it real good, checked everything, new gasket, fresh paint.
