I have been working to resolve the frequent failure to light on my Thelin Parlor pellet stove. I purchased it new in 2008 and later upgraded to the new firebox (per recomendation from Jay) My stove runs on T-stat with battery backup and is run on Low 24/7 cycling on the t-stat which is in another room. (it gets to about 85 in the kitchen where the stove is, but comfortable in the rest of the house.
I have TWO other issues with this stove , OVERFEEDING after fail to light(I believe is temp sensor issue and think I have a solution), and if power fails while stove is off it turns on the auger and fills the stove with pellets-As designed acording to Jay) but Iwill focus on the fail to light with this post.
The problem seemed less frequent at first, then got worse. I spent ALL last winter working with Jay to troubleshoot it and have replaced EVERYTHING except T1 sensor. I am an electrician with access to high tech test equipment and monitored it with an 8 channel digital chart recorder. I was unable to pinpoint any electrical problems with the stove.
Jay finally decided my problem was due to too many bends(T, 90, T) in the exhaust pipe too close to the stove(within first 6'-see attached pdf). I DONT BELIEVE IT. I think it is more to do with TOO much draft(due to 15' rise of 4" pipe through an old chimney. I believe this because I watched the flame get blown out from too much air, or just spew sparks untill all pellets near the ignighter were burnt away. If I cracked open the door and throttled the airflow during startup I could get it to every time.
I have closed my intake completely and raised the min fan speed during run cycle to try to compensate for the closed damper. This helps the situation a lot but did not solve it completely. It still fails to light probably 5 times per week. This setup also results in quick sooting of the glass.
Anyone else with a Parlor had this issue? If so, Have you found a solution yet?
