I'm still a noob to pellet burners, but something about the specs doesn't add up.
The specs list the output (or input?) at 58k btus, I'm assuming that's per hour as it normally is.
The specs also list a burn time on high (which I'm assuming is what generates that 58k btus) of 12 hours for 40# of pellets.
What am I missing? That math doesn't seem to work out at all.
Good point. I get almost exactly HALF of the 58K BTU when I do the math. Hmmm...
Unless you can somehow employ a fan to extract the heat off the metal , this stove doesn`t look to be an efficient design at all. I`m sure it works to some intended degree but the world is full of inventions that work but are of very limited use or appeal. Obviously it`s designed for use where electricity isn`t found but those places are far and few and usually with better alternatives available.
Wow! 200% efficiency!Good point. I get almost exactly HALF of the 58K BTU when I do the math. Hmmm...
If you believe everything he said, I have a bridge I'd like to sell you.
Does BTu output account for the radiance factor? These, like wood stoves, are designed to be a big heat sink in the room from what I gather. While the pellets only produce said BTu's, can the effective BTU be higher?
For comparison sakes what do other manufacturers claim? And are they also far off. I can't seem to find the pound per hour on my quad or an XXV for comparison.
Max burn time listed: 40# in 12 hours, 3.3 #/hr
At 8500 btu/# for pellets, that's an input of 28050 btu/hr
I believe what you're working with there is the "min" burn rate. Some stoves I've seen list the min and max #'s per hour this one appears to list only the longest burn on 40#s (last I looked).
At max burn time you have min pellet feed. So that might explain your 50% finding.
So much for my addled memory. Was working from your quote "Max burn time listed 40#s".
