We've all done it. Done something stupid and found ourselves asking, "What the heck was I thinking?"
I thought this would be a fun topic where we can laugh at ourselves. Please share your "What the heck was I thinking?" experiences.
I'll start. I just installed a water-to-air heat exchanger in the plenum of my forced air furnace. I need to run pex to the HX. I thought it would be a good idea to place a valve on the supply and return sides of the HX along with threaded unions in case I ever needed to shut the water off and remove the HX from the furnace. Didn't want to have to un-solder anything. This is on a secondary circuit so no need for a bypass in front of the HX.
So I run to Menards and I buy all of the fittings and the valves. I get home all anxious to start soldering stuff together.
I'm looking at the fittings and it's then that I realize that the way I had designed it would result in the valve being attached to the HX and the threaded union would be installed in the lines ABOVE the valves. In other words, if I unscrewed the union the pipe would be disconnected from the heat exchanger and the valves would be left on the heat exchanger! What the heck was I thinking?
So back to Menards I go. Exchange fittings and come back home and install them so that the valves stay on the lines (stopping the water from spraying all over) after the heat exchanger is disconnected via the unions. Duh.![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
