So, the "long and the short" of this is...............build up a hot, short-stack fire to temper the new stove........(I'd sure like to know how to tell when the stove is finished being "tempered" and ready to use "normally").
Then, get some wood in there and build an impressive looking fire in the new EPA-rated stove, ......let it build up initially hot (for how long, I dunno), and back it off to mid-range temps (somewhere between 500 - 650ºF) by cutting out some of the air with the dampener on the stove.
As needed, pull excess ash out of the firebox, leaving 1/2" to an 1" of ash on the bottom of (hopefully) active coals, setting more wood in, .....and just burn, burn, burn.
Run my forced hot air furnace fan to circulate the air, and use my ceiling fans as additional air-moving equipment, and only burn dry, seasoned, and properly sized wood in my stove.
Is that basically the picture? (Oh, I forgot going outside and moving some wood to the garage regularly, how much each time, not sure, and bringing into the house more wood, how much again each day, I'm not sure yet).
I think I can do this
-Soupy1957
-Soupy1957
