Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
so much for burning dry wood. It is almost imposible to dry wood in log lenght as the moisture comes out the end. I've cut oak logs that were down for ten years and the inside was almost as wet as logs cut in the winter.
leaddog
It seems like a waste - we're all getting burn times that are pretty close to that when compared with the amount of wood they're using. This is the reason environmentalists hate us!
Yes we get burn times close to that, but what BTU output are you? He's getting 10 hours at 700,000 BTU for a 15,000 sq ft greenhouse complex! Seems reasonable to me... Plus its mentioned in the video that its a gasification setup, which means it probably comes close or meets EPA requirements. I still get moisture production out of my unit using good seasoned hardwood, no matter how you split it and dry it. I like it......
