Chris Fallis said:I am wondering what kind of insulation goes under this beast and how you keep that insulation from getting crushed. I would think that you could install the boiler on blocks a few inches off the floor, but then the blocks would transfer a filled weight of between 7 and 17 tons onto the blocks and then onto your floor. I would rather distribute that weight evenly and widely to a concrete floor. Various folks have talked about wrapping these boilers with fiberglass or loose fill insulation, and that is a fairly easy process for the sides and top of the machine. Where I see a weakness is the big warm radiant surface on the bottom trying to heat my garage floor instead of my house.
Chris Fallis said:Another question relates to the day to day usage of the boiler. In the rear of the firebox is an apparently fragile ceramic secondary combustion chamber. In my last all metal firebox I could toss and stuff wood into it without real fear of damage. Has anyone thought of stacking up firebrick in the back of the box to form a protective “lip” around the leading edge of that ceramic? I am just thinking that I might be careful and explain to my family how to carefully loading the boiler to avoid damage, but someone, sometime, is just going to be pissed off and cold on a February morning, and won’t be so delicate about wood loading practices.
Jim K in PA said:....Another point with the GARN is that with the fan running, air is being drawn INTO the fire box. I have not had a burn in mine yet so this is purely speculative on my part, but you should not be getting blasted in the face with hot combustion byproducts when the door is open, so can take a little more time to load the box carefully.
Sawyer said:Hi Jim,
Have you thought of putting vermiculite in the curved area of the base? Paul reccomended I do that when mine arrives. He said it fills the void and warned about the cellelose insulation which contains acid which can harm the boiler. Maybe this is unnessary in your situation.
George
Chris Fallis said:I will also point out that once a good bed of coals was established in the firebox there was not a lot of desire to load the firebox at a leisurely pace. Standing 3 or 4 feet away from the open loading door I thought I was staring into the gates of Hades itself. The radiant heat was so much that I had to cover my face if I wanted to get close enough to chuck more fuel in. This was definitely a toss and run scenario.
