Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The Best-Built, Most Advanced, Lambda Controlled Wood Gasification Boiler On The Planet!
Thread startermikefrommaine
Start date
It's kind of a cross between a jetstream (top loader) and a woodgun (heavy, industrial looking construction) along with lambda controls. Even has optional extra thick steel construction for those that want it to last long enough for their grandchildren to enjoy.
(did you see that, I said something nice about the woodgun)
It is a little pricey.From what i have been told auto load is not in the USA yet.Also they have not gone through UL certification testing.But plan to in the near future.
Design looks very familiar and robust to say the least.
Saw a couple very similar to that a couple weeks ago at a conference in Wels Austria. Top loading, side instead of bottom gasification.......yep pretty much the same design.
The design is very similar, if not the same as a Kob residential boiler which is pretty much the cream of the crop over in Euroland. They are pricy over there too which is presumably why Viessmann (owns Kob) has not made them available here. It is a very good and robust design to say the least.
140KW is up in industrial sized applications and while $42K is a lot of dough it's not much more than you would pay for something of similar output. A pair of Garn 2000's for example will run about $32,000.
