Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
After removing the knock-out, the rough edges should be filed down with a coarse metal, half-round file or gently with a small grinder until the adapter fits snugly but easily. I used a file to take down the high points on ours and the adapter was fitting in about 15 minutes.
If I remember right, some ridge was left, but don't hold me to that. It was several years ago when I did this. Put the adapter inline with the knockout hole and then take a pencil or ink marker and draw a line around the edge of the adapter. That will guide you. The cast iron is fairly soft and filed pretty quickly once I got into it. A grinder or Dremel tool should also work, but don't get too aggressive.
