- Dec 30, 2013
- 273
today I purchased a hand held heat reading gun what the proper way to test it ? Should I let the stove run for for a bit ?? A certain number setting ? I have a harman p35i . Any insight would be greatly appreciated .
As I see it here's the problem with this. If you expect consistency it ain't gonna happen. Due to the seasonal variation among pellets and the intraseasonal variation in raw materials you MIGHT be able to say this pellet is better than this one at given time but ton-to-ton who knows?I've argued this many times. I for one do not have the equipment to properly measure temperatures. But many do and when asked to do their testing and report back, they never seemed to come back with data.....
Hmmmmmm
What stove model do you have?As I see it here's the problem with this. If you expect consistency it ain't gonna happen. Due to the seasonal variation among pellets and the intraseasonal variation in raw materials you MIGHT be able to say this pellet is better than this one at given time but ton-to-ton who knows?
Harman Accentra insert but I'm basing my statement on not only my experience but what I've read here re rebagging, regional manufacture and year-to-year performance.What stove model do you have?
Harman Accentra insert but I'm basing my statement on not only my experience but what I've read here re rebagging, regional manufacture and year-to-year petformance.
F4Jock, keep in mind that jtakeman does not have a Harman.Yes there is more than a little variance between this years and last years etc... , sometimes it really depends upon the makers control over the their raw materials.
This https://www.hearth.com/econtent/index.php/forums/viewthread/60581/ is a run down at one point in time using a consistent method for testing and done by one person who loves to clean his pellet eater.
No. I have a heating appliance not a science experiment. While I am an engineer (ME. ChE) I can read and accept the rational and logical conclusions of my fellow pellet users without having to replicate their trials or verify their observations and data. Fact: Pellet wood sources vary over unpredictable periods of time. Fact: Different wood types have different BTU output. Fact: Pellet mills bag for many different labels. Fact: Pellet mills have internal batch-to-batch production variations. Conclusion: Any measurement of pellet heat output is, while indicative of the efficiency of performance of a given production lot, relatively useless in predicting consistency of the product over time. Thus, unless you can test a representative sample of a given lot and be assured of obtaining your supply from that same lot you're not assured that the heat output will be comparable lot-to-lot much less year-to-year. But hey, if you're enjoying the process . . . .Have you tested and documented temperatures of the room air discharge with the proper equipment and consistent settings?
Totally agree. Never disputed this.Fact: Pellet wood sources vary over unpredictable periods of time.
Totally agree. Never disputed this. Interesting to note though that once compressed to the same density, ask wood species are relatively the same BTUs.Fact: Different wood types have different BTU output.
Totally agree. Never disputed this.Fact: Pellet mills bag for many different labels.
Totally agree. Never disputed this.Fact: Pellet mills have internal batch-to-batch production variations.
you will use less pellets with high btu content yes. But when compared in $/btu you quickly see that you save money with the cheaper pellets.Conclusion: Any measurement of pellet heat output is, while indicative of the efficiency of performance of a given production lot, relatively useless in predicting consistency of the product over time. Thus, unless you can test a representative sample of a given lot and be assured of obtaining your supply from that same lot you're not assured that the heat output will be comparable lot-to-lot much less year-to-year.
Good point.However using a Harman requires that you pay attention to how you conduct the test and simply pointing an IR temperature gun at the right spot ain't going to tell much, there are other stoves out there that provide a damn near identical output air temperature over their entire firing range.
Which Harman doesn't. At least not in Room Temp. I judge my pellet by daily consumption over time, consistency of supply and ash generated / cleaning frequency. So far the best I've hit in those respects are Lignetics.However using a Harman requires that you pay attention to how you conduct the test and simply pointing an IR temperature gun at the right spot ain't going to tell much, there are other stoves out there that provide a damn near identical output air temperature over their entire firing range.
Yeah but if I have to clean every week, and barely make it that far as I did with PA Pellets or GS I'd rather pay a few bucks more a ton. With Lignetics I got for $235 a ton I've gone three weeks between cleanings and judging from the condition of the stove could have gone more. Can you say the same for cheaper pellets? Can you GET cheaper pellets? I haven't been able to in NEPA, even at Big Boxes.Totally agree. Never disputed this.
Actually not quite true. Hardwoods vary about +/- 600 BTU per pound depending.A Chem E outta know that it is all 8600 BTU per pound. Just how fast or how slow it breaks down and let's then go is the difference.
I envy you the price. Around here not very much variation even at the "Wall."I have gone three weeks burning 24/7 in room temp manual with $197/ton pellets bought at Walmart. I know I could have gone longer without a problem too. But I love my stove and hate to abuse it.![]()
