Hey all, first time poster here! This forum has proven to be a plethora of knowledge. First, I'll apologize for asking about something that has been discussed at length already, but I wanted to post about my specific conditions so that all factors can be considered.
I bought my house about 4 years ago. There is a finished, walk-out, basement which had a chimney access which had been plugged. Presumably for a wood or pellet stove at one point or another. I went and bought an old Huntsman wood stove to use there. Outside, there is a triple wall stainless pipe that runs parallel to my fireplace up on the floor above. They are boxed out on the side of the house and run up quite a ways. It is an 8" pipe and its about 35-40' tall. Off the stove is a 6" pipe that has a 6 x 8 " reducer where it goes through the wall (single wall black pipe inside). When it is very cold in Northern New York, and last night was -20F it can be an issue. Once the draft is reversed, I have no issues and the stove burns beautifully. However, priming it can be challenging. Typically when its in the teens or higher I can crack a window, fill the stove with newspaper and light it with a torch while shutting the doors it takes off pretty well, following up with kiln dried kindling. But this morning I filled the room with smoke trying to get it started, and the stove hadn't even cooled down entirely, though the pipe was stone cold.
I've seen draft inducers, which are not revered too well in the wood burning applications, and even seen the "draft collars" which are crazy expensive and I can't help but think there must be a better way. I will say that my house is quite drafty, unfortunately, it's old. The room the stove is in is block and only has cheap open core foam insulation behind the paneling. One wall is under-ground (I'm built on a hill w/ slab on grade). I tried to prime it with a map gas torch with no luck and am no considering a blow dryer or heat gun, but am not optimistic. If anyone has some suggestions I'm open!
One other thing to mention is that the propane furnace is on the same floor and its open air throughout. There is a return grill cut into the return plenum, so there is a vacuum being created from that as well.
Thank you all in advanced for your help and knowledge.
