I tore down the ugly tile behind my woods stove and I believe I have some clearance issues that I need fix before I covering everything up again . So I have a terracotta crock going through the wall with only 8” clearances to some of the wood. I realize it should be 18”. I can’t remove all the wood because my chimney is not wide enough and I have sheeting from my siding around 10” away.
I have been looking at double wall thimbles to install to bring that clearance need down to 6”. My question is how should I handle the old terracotta crock? If I removed the whole thing I’d have a 10” hole going into my block chimney, would it be ok to trim the terracotta crock flush with the block chimney? Then secure the thimble to the chimney and run it through what’s left of the terracotta crock? If I removed the old crock I’d be left with a hole much larger then the thimble.
Is there anything I can do to use the old crock? It’s in good shape other than the clearance issue
![21DFC228-31AE-4980-A90C-687C7B1B93F1.jpeg 21DFC228-31AE-4980-A90C-687C7B1B93F1.jpeg](https://www.hearth.com/talk/data/attachments/300/300674-557d65c0e376cb7f22a93b735dbb40f2.jpg)
![93AF3FFB-1F30-430C-9223-B9C3B5E2B7C0.jpeg 93AF3FFB-1F30-430C-9223-B9C3B5E2B7C0.jpeg](https://www.hearth.com/talk/data/attachments/300/300673-c7791b75bad91f44cb32efbc79aecf71.jpg)
