Termovar trouble
chuck172
1,047
Sussex County, NJ
Has anyone run into any problems with their termovar valve sticking and restricting flow? I'm not sure yet, but I think mine might be giving me problems.
When I fired up yesterday I first thought that something was not right. As learned in farm troubleshooting 101, tap item to see if it returns to service. With that done the thermometers returned to the normal readings from last year.
My next step would have been to open the valve housings and check for debis or sticky valve. These are easy to access, there are many cut open pic's online to see where to look.
A little confused here. What opens the termovar?. The boiler water temp. or the water temp from the heating load?
I wonder if I'm trying to circulate too cold boiler water. What should my circ. aquastate be set at. I had it at 145. Could be I'm not giving the mixing valve a chance to fully open!
I fixed it!!
Hogstroker, your a genius. I took a hammer to the mixing valve. nothing happened. There is a swing check near there. I tapped it. A miracle. The check was sticking. What a difference. Everything works.
Thanks!
