Termination Vent Placement
Busy_Bosco
13
West Virginia
Hi all, having trouble installing my first pellet stove.
Problem is there is basically nowhere appropriate to place my termination vent outside.
I finally think I have a spot, but I realized the exhaust from the vent is fairly close to my AC units compressor and electrical line... ugh.
I have attached a picture of the area and marked a potential exhaust spot with a red dot (I know theres a window close, but it has been completely sealed with silicone and quarter round).
I also attached the page from the stoves manual about exhaust clearances. I think L answered my question, but I'm not entirely sure I'm reading it correctly.
Thanks for any feedback!
It is interesting that they only require 12" if below/beside a window. Is that a clearance chart for use with an OAK (outside air kit)? Although looking at my stove install manual, it does say 12" from a permanently closed window.
I believe you are correct and L is your answer about proximity to services
No gas meter or vent blowing out or sucking in there? Your probably won’t be running your AC while running stove anyway. I think you’ve got a good spot.
