ok, my control board burnt out again for the 2nd time in 1 year, the auger does not get power to it but i found that if i jump the power circuit to the igniter circuit, the auger will spin when it is supposed to & not when it is not(the green feed light lites up.) only problem is, when the system stops calling for the igniter to burn, the auger stops spinning. my question is, can i do anything temporary to get this auger to spin without spending 400 for a new control board.
i am out of work & really strapped right now.
i am thinking about maybe a dimmer switch to slow the rate at which the auger motor spins. although it will spin all the time, it will spin slower, therefore i can adjust the rate of pellet drop manually.
the other idea was to find a timer which i can set for 10.20, 30 seconds on & so many seconds off(that may be a little harder to find)
