I purchased an old house that had a wood stove installed in the basement.
‘The foundation has failed and needs replaced. I have torn everything out of the basement in preparation for the foundation replacement.
I need to safely temporarily install this stove upstairs until I can get the foundation replaced.
I have 2 sheets of 4x6 feet aluminum diamond plate 3/16.
I plan on installing the metal with a 1 inch air gap on the wall. Will one sheet be enough protection for the wall 4 foot wide 6 foot tall or does it need to be 6 foot wide and use both sheets.
I think I can figure out the wall protection to get the stove 12 inch from the wall but the floor protection is what I can’t figure out.
just one layer of brick the recommended size in the manual is over 400 pounds.
I have to lift the house up to replace the foundation and want to keep the weight down for this temporary installation.
Anyone have any ideal for the floor? If one 4x6 sheet is enough for the wall the I was thinking of putting a couple bricks down on the plywood to support the 3/16 aluminum plate and a couple more bricks under the feet of the stove and then put the stove on top of the plate. That would leave over 3 inch air gap between the diamond plate and plywood. I could also add 4 bricks to the top of the plate to raise the stove up a little more.
![Temporarily install fisher grandpa bear Temporarily install fisher grandpa bear](https://www.hearth.com/talk/data/attachments/299/299606-94c3ced101d80a30387ea7005650f18e.jpg)
