Temp Wood II manual and some weird happenings
Jclout
149
Southbridge, Massachusetts
:-S Hello brothers, does anyone out there own a Tempwood II wood stove? I purchased a used one not to long ago and fired it up just last week. A couple of weird things happened, The first night I cut the draft way down, just a couple of sliver openings. I woke in the night to the smell of smoke, I thought. When I checked it out there was a large puddle of liquid creosote on the cement floor that had leaked out of the stove pipe, (maybe mixed with some water ??? Why else so liquidy?). I don't think that the wood was that wet and the chimney was certainly clean, did it myself. Tried it again the next night with different wood and more draft,-noo problem. Another thing that happened was that when I checked it in the night, I opened the key damper and both vents quickly and all the way, within 5 seconds the gasses ignited and it sounded like a firecracker went off in the stove, wont do that again!. I could use some thoughts on these things and if anyone has a manual I would be willing to pay for a copy,(The manufacturer is out of business). I could use some tutoring on the A,B,C's of properly burning wood, been burning since 2000 but since joining Hearth.com I see that there's more to it than meets the eye.
Thanks!
http://mb-soft.com/juca/print/firewood.html
Check this page out, it will help you understand the basics of wood and attributes of cutting and seasoning. Remember these are the basics and eventually you will make slight adjustments to your own liking. In so far as the wood stove, no I idea about the manufacturer, but from what I am reading, really green wood, really, really, green wood.
