Is anyone using a tekmar 156 difference setpoint control to manage their domestic hot water tank? I will be using a sidearm heater and a circulator on the domestic side and a load circ with a zone valve on the boiler side. Should be able to use the tekmar to control the zone valve, the load circulator, and the domestic circ depending on water temp in the tank. Might have to add a relay or two.
Where do you think the best place to put the sensors would be? It would be nice if hot water tanks had aquastat wells built right into them.
Normally I would just run all the water from the primary loop through the sidearm... but with thermal storage, I want to move water through the system only when necessary to aid in stratification in the tanks... thus the DHW is tied in as a zone.
cheers
cheers
