Tarm Question
lawandorder
193
upstate new york
Started burning yesterday and still running off of storage so far today. I noticed that my circulator pump on the Tarm is running even though there is no call for heat and the Tarm is shut down. Is this normal?? Dont rememeber whether or not it did this last year. Thanks
Your primary circ should run anytime the boiler temp is over the setpoint regardless of demand. Can you control the pump-on temp? On EKO's you can set when the pump turns on and off. I suspect you should be able to do the same with the Tarm...
My circulator shuts down after boiler cools off. Maybe somethings not wired right? I have the Termovar loading valve on my unit.
i am having a problem with the water circulating thru boiler whenever a zone opens up in the house. I've been talking with Bioheat and have to send some pics of my setup. Just got to get the digital camera back and I should have my problem fixed soon. Bioheat has been great to work with on customer service. If all else fails, call them.
