1.The Tarm 40 no longer has an issue with condensation. The issue seems to have cleared itself up.
2. I am getting good burns with gasification.
3. I adjujsted a valve and I am getting hotter water to my baseboards and more heat. Still... at times.. I have 3 or 4 zones calling for heat which lowers my temp on the hot water circulating at that time. I have to then turn down one thermostat and let that zone heat up the room first. Then when the room is up to temp... I can let the other 2 or 3 zones get to work with a higher water temp.
4. The Tarm is awesome... so much heat from so little wood. I am calculating heating the whole house up to 70 and all the hot water( 5 people) using 4 cord of hardwood and maybe a cord of pine. This is an estimate.. but I think it will be close. From December to mid March. My house has a high heat loss as well... and 2000 sq ft.
5. Smoke is not an issue. I have learned how to load and clean properly.
Questions:
1. The temps here are crazy lately. Sometimes it is 40 during the day and 20 at night. This is tough for me to gauge how much wood to use and when to load. I am learning how to use small fires to have less idle time.... but I think storage would be the ideal solution. How do others without storage deal with the issue of temp swings and burn times? Are there other things i should try besides just judging the size of the fire?
2. Storage. I want pressurized. My question. Hot can I get this storage? Can I get it up to 180-190? And if so.. I am curious to find out how much storage I would need and at what temp to get me by for teh amount of hours I may need ( tons of variables here i know). What is typical of those with storage? Can someone describe how there typical day goes with using storage?
Questions:
