NHFarmer said:How have the coils been going?I am still really torn on the coils vs.plate hx.They look good so far.
Not sure what band board is, but my plan is to put fiberglass bats between the studs then put cover it all with some plywood or hardboard.Hogwildz said:Are yout going to put any band boards around the box?
NHFarmer said:Do you have any closeup pix of the coil 45*?
free75degrees said:Not sure what band board is, but my plan is to put fiberglass bats between the studs then put cover it all with some plywood or hardboard.Hogwildz said:Are yout going to put any band boards around the box?
Hogwildz said:Meaning boards tied together arounf the outside of the box, especially near the top & center. Thats going to be alot of pressure from alot of water pushing on those sides.
I can see you have it set in the footing at bottom, which is great. But what about the top & center. I am not an engineer, but wall studs & a mitered top plate aren't a heck of alot to withstand the amounts of pressure a tank that size filled with water is going to put against those walls.
Hard to tell from the photos, but looks like no support at the corners either. Just seems to me with the water pressing against the corners & sides in that amount, is going to be quite a few pounds of force.
Would suck if the seams split open, or walls gave way.
chuck172 said:If it were mine I would weld angle iron round the top and middle. Intersecting at the corners. Anchor to the concrete walls. Maybe even then prop the sides up with steel gussets, anchored to the floor. Probably overkill though.
Did you make the coils out of type L 3/4 roll (soft)tubing?
I don't see any stiffeners on the coils to keep them straight and stretched.
Like NHfarmer, I too am undecided between coils and plate HX's.
good job, keep up with the pics. please.
Adios Pantalones said:What is the liner?
This thing is pissa
sparke said:Very impressive set up. You should get great stratification on that tank. Don't forget to put a pre-heat coil to your DHW (maybe you already mentioned it). I wish I put one in mine. The 50* water sucks the life right out of the tank... What is the cement looking product you are using for the liner?
The dirt hole was about 3 feet deep. There is a 4 inch concrete floor and 4 inches of insulation, so the actual water depth below grade is a little over 2 feet.solo40 said:Your tanks is what I would like to do. I want to dig out my 4 foot crawl space a few feet and put concrete blocks at
the bottom and wood at the top. How deep is your tank?
Ethan
