How does fiberglass insulation work on pressurized propane tanks? Can I use it to get through this winter? Next year I'll box it out and get a little more creative.
LOL!!chuck172 said:Are there any negatives in using blown in cellulose fiber insulation? Seems pretty easy to box in the tank, buy the insulation, rent the blower from Home Depot.
machinistbcb said:I just blew in cellulose around my tank. It worked great and went quickly. I blew in 28 bags in a few hours. Right now I am using ther tank for DHW only. I start at 180 degree on saturday and the following saturday I am at about 145 degrees.
chuck172 said:Could you give me a ball park figure on how many bags I would need to insulate one boxed in 500 gallon propane tank?
DaveBP said:I noticed when blowing into corners and under some framing that it seemed to 'pack' in a little when you force it with the nozzle, like the dense pack done commercially. Probably not as dense though, since they use water to moisten the cellulose in that technique.
SO you are getting your DHW for one week off of one fire? How are you transferring heat from the propane tank to the DHW? A superstore tank? How many people in your household?
What size pressurized tank are you using?
machinistbcb said:SO you are getting your DHW for one week off of one fire? How are you transferring heat from the propane tank to the DHW? A superstore tank? How many people in your household?
Yeah 1 week, probably more like a week and a half if I let the tank get down to 120 degrees. I am using a 40 gallon superstore with 3 people in the household, and I am using a 1500 gallon tank.
Brian
chuck172 said:Boy what good advice on this thread. thanks
WOW- as someone who’s in the process of planning and building my system, this is encouraging news--please tell us more specifics about how you have the superstor tied into your 1500 gallon tank-- do you have a preheat coil for the cold household water running through the 1500 gallon storage before entering the 40 gallon superstor (so that you’re getting several bites at the apple at heating the DHW at a couple of levels/ stages), or are you simply using the hot water from the 1500 gallon tank to push through the “regular” heat exchange coil in the superstor?
chuck172 said:Can the insulation be poured in instead of blown in?
DaveBP said:When I was researching cellulose for my attic I learned that some brands use sulfate compounds in addition to the borates to make it non-flammable and to keep insects from inhabiting it (boron kill insects). The 'Cocoon' brand that LowesDepot around here sells is one of those. I don't know if it's a trivial issue or not but I think of sulfates as corrosive. Not going to be much humidity around the tank unless there's a leak that you don't detect for a while but why add one more thing that can go bad. National Fiber uses only borates and I went with that since that's what my drywall supplier sells for the same price but he delivered my 90 bags and put it on the porch with a telescoping boom at no additional cost since he was bringing the drywall, too.
The chart on the bag I have left over suggests that one bag will fill about 25 cu.ft. But that is after settling from full fluff condition as blown in loose in an attic. I noticed when blowing into corners and under some framing that it seemed to 'pack' in a little when you force it with the nozzle, like the dense pack done commercially. Probably not as dense though, since they use water to moisten the cellulose in that technique.
Wear a mask. Very dusty business. Borates aren't particularly toxic to warm blooded animals but why fill your lungs with it. No itching!!
All bets are off on R value. The temperature differences in this application, especially outdoor installations, are way different that the standard definition of R values. For outdoors, I'd just use the universal constant Pi(3.14) times what you think is adequate.
I’m in Wells, Maine and am doing a Garn installation soon. Garn is quite paranoid about corrosion and doesn’t recommend cellulose for that reason. I’m curious about the National Fiber stuff you speak of. Where did you get it from?
