I am sizing pumps for my GARN initial setup. Initial setup will be to supply my house with HW for this winter, then adding additional smaller building loads over the next couple of years.
I am planning a primary loop with 1.5" pipe and a TACO 009 VSS pump. There is a total combined max load of 135k Btuh planned when all three building loads are running. That pump gives 10GPM right in the middle of it's curve, which is what I expect to need at max load. Head loss in the primary is relatively low, with less than 30' of pipe run and about 6 elbows. The VSS will provide boiler protection by monitoring return temp and ramping flow up/down to prevent excessivley cooled water to return.
For the house loop, I have a max load of 70k Btuh running through 1.25" barrier PEX. Total run length of pex (S&R
is 230', with about 10 elbows. I am planning to use a TACO 007VR pump. I calculate that I need 7GPM and with that amount of head loss, the 007 seems to fit the bill. The VR will allow a simple outdoor reset of the pump speed to accomodate varying demand based on outside temps.
Pump location - for the house loop, should I mount the pump in the basement near the manifolds or should I mount it just off the primary loop near my GARN? The basement location will give me max NPSH, as it is about 8-10 feet lower than the water level in the GARN.
PLEASE tell me if I have missed the boat on this. I have been crunching numbers for days, and I am getting bleary eyed. :-S
Thanks.
![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
Thanks.
