My pump on my boiler is leaking at the cartridge seal. I have had it apart a few times and everything looks good. No nicks in the seal no pits in the casting ect? Do they just sell the cartdrige seal?
Thank you,
Rob
Thank you,
Rob
heaterman said:A 0013 is going to be happiest running about 20GPM @ around 18 ft of head. That kind of flow dictates pretty decent pipe or tube size. What is it connected to? To hit those numbers it would have to be hooked up to 1-1/4" or maybe even 1-1/2" pex.
For example: That circ, connected to a 1" pex loop of 200' in length is going to be at the top of it's curve developing about 25-26 ft of head and around 10GPM. It's not going to live long operating in that range.
The only way to fix it is to buy a new cartridge. The seal is not available as a separate piece.
http://www.taco-hvac.com/uploads/FileLibrary/0013Sht.pdf
taxidermist said:150' each way so 300' round trip. I too tried to talk with plumbing supply houses around here and only a few said they could get them. Will the wilo or grund direct fit into my taco flanges? As to the guy who sold me the 1" pex I am sure he sells it the same way todayI even asked him many times if it would be big enough and he said "yep" to over come the head pressure we just added a bigger pump
!! UGH!! I heat my storage pretty good but always looking for a better way.
Rob
heaterman said:taxidermist said:150' each way so 300' round trip. I too tried to talk with plumbing supply houses around here and only a few said they could get them. Will the wilo or grund direct fit into my taco flanges? As to the guy who sold me the 1" pex I am sure he sells it the same way todayI even asked him many times if it would be big enough and he said "yep" to over come the head pressure we just added a bigger pump
Rob
I think the 0013 is standard flange size but i would have to look it up. If it is then either of the two I mentioned will bolt up.
huskers said:heaterman said:taxidermist said:150' each way so 300' round trip. I too tried to talk with plumbing supply houses around here and only a few said they could get them. Will the wilo or grund direct fit into my taco flanges? As to the guy who sold me the 1" pex I am sure he sells it the same way todayI even asked him many times if it would be big enough and he said "yep" to over come the head pressure we just added a bigger pump
Rob
Hopefully, you have some "give" on one end of these flanges if this where your pex connects. The Taco & Grundfos are about a 1/4" different in lengths I believe, at least the 007 and 15-58's are. I have one Taco 007 on the primary loop in my setup that was my first circ back when I just heated the pole barn with a simple heater tied right to the boiler loop. Everything I've bought since then is the 3 speed Grundfos 15-58s for my hybrid primary-secondary (ie. circ intensive) setup. I wish they were all 15-58s but I couldn't see not making use of the 007 I already had. Now since the 007 is connected to black iron, I will probably need to stick to the 007s or the newer Taco 3 speed version if it ever fails. FWIW, I believe the Taco 007 and Grundfos 15-58 flanges are interchangeable, though not sure about the 013. You could probably check website to see if 007 and 013 are different. I had a set of Taco green 1" flanges that I thought of reusing on a Grundfos but decided against since the local plumbing supply house sells red B&G ones for $6 apiece that match color better on the 15-58s. Wife already says I hope we never have to sell our house when she's down in the utility part of the basement and my plumbing job actually looks fairly decent.
in hot water said:you need to move about 17 gpm through that boiler to move 175,000 btu/hr. I doubt that a smaller circ will move near enough through that much tube (pressure drop) that larger pump was suggested to compensate for the small tube size. To move that much energy with a low head circ you would need 1-1/2" pipe or equivalent.
Remember 1" pex is a much smaller ID compared to copper or steel pipe.
hr
taxidermist said:Anyone know? if you can run 2 pumps?
Rob
in hot water said:sure, in parallel would double the flow, in series almost doubles the head, a bit of pressure loss through the second series is all. Here is what it looks like in series. I like to see a short piece of pipe between them to allow any turbulance to sort out, but flange to flange is used also.
hr
taxidermist said:in hot water said:sure, in parallel would double the flow, in series almost doubles the head, a bit of pressure loss through the second series is all. Here is what it looks like in series. I like to see a short piece of pipe between them to allow any turbulance to sort out, but flange to flange is used also.
hr
If you say I need to move 17gpm thru the boiler whats my best setup for a 300' round trip thru 1" pex? Should I be looking for gpm or a pump that pumps more head pressure? As you can tell I dont have a clue about pumps I just know I got screwed on 1" pex and would like to make my system work the best with what i have.
I run my eko 60 like a eko 40 with only 1 fan and 1 nozzle I have 1000 gal storage closed system.
Thank you,
Rob
heaterman said:This is maybe already on here somewhere but is your storage by the EKO or at the end of the 150' run?
