Doing the install now and removed access panel, the Skytech t-stat has terminal leads at the end but the control board seems to only accept the wires stripped in the block.
Any way around this, i'd hate cutting the t-stat terminal leads but if that's the only way then..... :-S
Couple pics here, one showing the t-stat wire leads/terminal, the picture on the left shows the green block on the board to connect the wires to, 2 small holes to the bottom front.
