As you may have noticed... This is my 1st post ...
well here goes...
My wife and I are building again, and are planning for our old age and the rising costs of fuel.
We have decided on a radiant floor heat system .. called Ultra-Fin ( http://www.ultra-fin.com/index.htm )
The advantage of this system is that you can run it much hotter (140 -180 deg.) than conventional in floor radiant heat.
The Boiler we have chosen is a TARM MBO 30 (75,000 btu) wood w/ coal grates added. We are purchasing this boiler used and Tarm USA is going to sell us the coal grates to convert it to burn anthracite as well as wood. (we canot afford a wood gasification boiler at this time, so we have opted to setup w/ a used boiler till we save some more money)
We have an estimated 24,000 btu 4 zone (the house)load figured for 20 degree winter days and maintaining 68 inside.
We have found a cheap local source for either 500 or 1000 gallon used propane tanks at 7 cents a lb (roughly 42 bucks for a 500 gallon tank) and 100 bucks to deliver. (yahoo
1st question... Will I have to have any welding done to these tanks to utilize them as heat (water)storage? there are 2 1.5" fittings on the top and 1 larger fitting on the bottom.
2nd question... Are there any problems assosiated with having these sitting in the (drive-in) basement?
3rd... Anyone have a manual for a Tarm MB30 they want to share?
Thankyou
~david 'n tina
well here goes...
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Thankyou
~david 'n tina
