I've settled upon a a primary secondary design with the boiler and storage both isolated like zones and 3 heating zones.
I don't understand the storage loop. I have a 1500 gallon unpressurized tank built into the basement. The EKO 60 is 6 feet higher in the garage.
1) Will 1 heat exchanger and pump be sufficient for the storage loop or do I need 2 heat exchangers and 2 pumps?
2) What kind of heat exchanger(s) should I use for such a large storage tank?
Here is some background for your consideration:
There is a forced air oil furnace with 117K BTU rating (it heats house well)
DHW is oil fired 40 gallon tank (never ran out of hot water yet)
The Barn is 215 feet from house with 500 sq. ft. already developed (to be heated). It can be heated with 2000 watts at present
Additional development space in the barn could reach 5000 sq.ft. over several years
I appreciate your input to my steep learning curve.
