I think I'm going to switch to ATF fluid in my splitter. I was splitting yesterday and the temps were in the 20's. It seems whenever I have time to split.....it's cold out. I've read a few threads where ATF is recommended in cold temps. My MTD (about 10 years old, 25 ton, 6hp B/S) doesn't get a lot of use...at least not compared to most of you.
If I switch, can whatever hydraulic fluid that is left in the cyclinder and hoses mix ok with the Dextron, or do I need to do flush it out in some way? I haven't found too much info. after searching here and the guy at the NAPA store weren't sure.
Second, if I decide to leave the hydro fluid in, can I damage anything, such as the pump or cyclinder seals, if I use it in such low temps? Yesterday, I hooked up a magnetic heater to the tank.
Thanks for the help....
