I picked up this Lopi on the marketplace for $240! It needed some cleaning up to say the least... we were having lots of cold air infiltration, so I insulated around the box with roxul and above the block off plate. It’s doing a nice job!
Looks nice in the new house! Was there anything in the fireplace before you put the freedom in there?
I looked at a freedom bay at your shop before I bought the Alderlea, I could not meet the mantel clearances for the Lopi and the wife is not to crazy about mantel shields.
When I bought my current home it came with the exact same stove. I still remember the screech that it made when working the bypass and adjusting the intake. The baffle was not fragile ceramic but bricks and steel. My install was just a short hunk of pipe dumped into the masonry chimney above the damper. Later I installed a liner.
The air control is a few pieces of steel with some stiff springs between them that are sandwiched under the firebox. A set screw allows you to remove the whole assembly for cleaning and lube.
The bypass rod will screech on the stovetop adaptor or elbow. The notch needs to be made in such a way that the rod doesn’t contact the adaptor. It takes some work to get it in the right spot.
