super patriot wood stove
sydney
5
boston
does anyone have any info on a 1975 era wood stove made in ct.under the name
  • [Hearth.com] super patriot wood stove
Sorry, Sydney, I've never heard of it. 1975 I was frantically shopping for a flower-embroidered white belt to go with my red bell-bottoms. :bug: Rick
Sid: if you are feeling really patriotic, maybe just buy it?? Or not :roll:
Never heard of it but I guessing it's probably one of the 1st generation air tight stoves to hit the market back then.
Back then I was heating with a Ben Franklin stove with the isenglass that you had to constantly feed wood to...it keep you warm but very busy. Think I got my first Shenandoah R65 model airtight stove around 78 or 79...man what a difference in holding a fire compare to the Franklin stove it was a Godsend...but nothing compared to the EPA stoves of today.
imo those old airtight stoves are OK for camps or hunting lodges but with the cost of wood today I dunno about using one to heat the house but if your laid off and that all you can make do with then go for it cause it will probably do the job.
Just today moved our R-77 Shenandoah into a position I can wire brush and paint it...gonna ask 75 for it, works fine but the wife tired of it...cause it was boring. Go Figure!
Sounds like it was pretty efficient for it's time and kind of similar combustion wise to the new down draft stoves? Do you have one Sydney?
As Craig said, it looks JUST like a tempwood to me. Not a whole lot to it, as it's just a top loading steel box.
Thank you for your info,very helpful. I was given one for free with water panel and 40 gal copper
water tank ,pump, tstat included.Ive been burning anthracite in my old nashua stove in the living room
very happily and as a master plumber i thought i would play with this and see what i could do.
side note joined in 1/08 never posted glad I did thanks again Syd
These stoves are sort of interesting. The design with the air coming in on top limits the fire to a certain extent...which is good in this case. These stoves do not overheat easily - and the Patriot also has a bimetal element in the air inlets which shuts them if the stove was to overheat.
These stoves will take a little time to get used to....maybe try setting the fire upside down (some info on starting fires that way somewhere around here).
not sure of interior is a fire grate needed or do you burn on the base
should ther be firebrick of some sort
As I remember, there was a layer of FB on the bottom - no grate used or needed. There may also have been a layer around the lower part of the sides - look for any indication (brackets, etc). My guess would be that there was......easy enough to install - get split bricks at your local masonry supply yard.
there are fb on the sides and ends on angle but not sure of the bottom
Im not on site will check it when I get back to it.
