Super Cedar firestarters 30% discount
Use code Hearth2024
Click here
My air control linkage on the Super 27 is very very squeaky and noisy. Is there a lubrication product that can be used safely in/near high heat? I tried graphite but could not get it inside the welded box around the linkage.
I've used WD 40 several times with great results. I spay some in the front where the metal rubs the top and also shoot some to the back where the rod passes through. I usually do this after starting a fire before the stove heats up so that the odor is sucked into the stove and doesn't make the room smell bad.
