Summit/T6 Primary/Secondary air inlet to the box
10-cc
129
St-Bruno, Quebec, Canada
Hi,
Is anybody know where are the holes to the firebox located?
Thanks, the reason I ask is that I cannot see any holes when the manifold is removed. How about the secondaries is the secondary enter the box from the same place or from the back?
I notice that when there are too many hashes in the box I need to increase air, probably because the hashes cover the holes and it restrict air inlet, is that possible?
thx again
thx again
It is ~ 3" rectangular box under the manifold in the center.
I believe I notice the same, and it burns best with less ash.
the main air goes in at the bottom front.its controlled by air lever that you control.that air goes up then down over the window (air wash).
the secondaries go in from the bottom back of the box,underneath.it isnt controlled.
the boost manifold is the air that goes in through the EBT at the front bottom of the box then through those holes inside bottom front of the box.
