I bought a PE Summit insert because it offered an outside air intake. I called PE prior to the purchase and discussed what was required to do the installation.
Apparently there are many holes which breach the outer shell and allow cold air to flow to the inside room air when the unit is installed as instructed. I found at least 12 square inches of holes This leads to quite a draft when the stove is off.
I contacted them and they refuse to even send me a picture of the back and underside of the stove so I can determine where all the holes are in the outer casing.
They admitted the manual was incorrect and the insert in not "really" compatible with an outside air intake they would leave this up to the "marketing department". So much for honest and ethics in this world......
Can anyone post pictures? I would like to seal this off without removing it as it is quite heavy.
