I'm in the process of restoring my Grandparent's 1951 Floyd-Welles (Royerston, PA) porcelain skin combination range. If there's anyone out there with the "Bengal" range or the identical "Happy Cooking" they produced for Fuelane Gas co, I'd welcome meeting them...there aren't many of these around anymore...once very popular in New England and PA.
It is now working under wood with a straight-up double wall stove pipe. I am tuning up the gas works with the remote help of a vintage gas stove pro in Oregon...now retired...who restored and sold them for 35 years.
The fireboxes on most are small, mine is no exception and I'm still on the quest for the coveted Overnight Burn. I'm using this as my sole heat and for cooking. My cottage is about 675 Sqr Ft. I've only had it in service a month and still learning it's quirks, but it did indeed heat a good 800 ft of my Grandparents house through the winter. Unfortunately they're no longer here to learn from.
I think the majority of the unwanted air suck if from the cook top...I can see it visibly at night. My initial thoughts are to install a flat gasket around the edges and perhaps the center seam for the 2 base plates to sit upon. They take up half the range...the other side is propane.
Also, while I'm at it here...for those of you in the Metro NY area and on L.I: Is there anyone specializing in "tuning up/repair" of vintage cookstoves in regards to the wood part? I'd like to have the springs on the draft and damper rods tightened or replaced as needed...the main damper is open and closed only right now...obviously worn or needs adjustment.
The fireplace stove stores won't touch anything they haven't sold...probably a combination of headache and liability.
Thank in advance for feedback and Happy Holidays!
